Today was the day my '63 was supposed to go back to the body shop for rear bumper installation and finishing touches. My brother got up bright and early, fired her up, and headed 25 miles to the shop. Before he got out of town he turned on the wiper because of some drizzle. Then the wiper linkage came loose because, although I procured a chrome replacement arm for the passenger side, I hadn't installed it yet. [}] He rushed the car back home and fixed the linkage after cursing that a midget couldn't fit his hands up under the dash to properly work on it. He set out on the road again, with the car running smoothly for about 15 miles, and then it suddenly died. He pulled it off into a Super Mkt parking lot and started scratching his head?? He pulled off the new gas filter and found it completely clogged again. We called up my son and he drove my '66 Commander to meet my brother to help out. He picked up a new gas filter along the way. Once it was installed along with a liberal dose of carb cleaner, the car fired up and they set out the remaining 10 miles to the body shop. Five miles later, and in the absolute worse part of town, the Avanti died again. This time she was hopelessly clogged in the carb. No gas would squirt when the pump was mashed. Both guys worked till it became evident the car just wasn't going anywhere under its own power. So, instead of going to the body shop, it had to be towed to my mechanic another 25 miles away. OK, I'm finally getting that dam* rusted gas tank fixed once and for all!!! Then, I'm having all the gas lines cleaned out and the carb rebuilt. And, while it's at the gsrage I'm getting the trans fluid and filter changed and the coolant too. Who knows what else they'll find to work on...?[?] On an even brighter note, my son noticed while following the Avanti that it continuously expels white smoke from the right tailpipe. I sure hope that's a blown gasket instead on a cracked head or cylinder. [V] Anyway, the haunted Avanti is up to its old tricks again. It just doesn't want to go back to the body shop for some reason. [xx(] How was your day?
[img][/img]
edp/NC
'63 Avanti
'66 Commander
[img][/img]
edp/NC
'63 Avanti
'66 Commander
