View Full Version : radio antenna no up or down
bradnree
01-24-2007, 08:05 PM
What heighth should the antenna be at the max and then at the minimum. Is it a tape that coils and goes up and down to drive the antenna and can you uncover it. I have the main housing cover off. Mine will not move in either direction by turning the wheel on the kick panel on a '47 Studebaker and a '52............Brad
JDP
01-24-2007, 09:51 PM
It's a cable that winds around a reel with a clutch. The cover unsnaps and you can see the works.
64 Commander 2 dr.
63 Avanti R1
63 Daytona convert
63 Lark 2 door
63 Lark 2 door #2
62 Daytona HT/ 4 speed
62 Lark 2 door
62 GT Hawk 4 speed
60 Lark HT
60 Hawk
59 3E truck
52 Starliner
51 Commander
rockne10
01-24-2007, 11:05 PM
There's a spring steel pressure plate that fits against a fiber disc. If it has lost it's grip and worn a groove in to the disc you may need to secure it in some manner. It's been years since I had one of these apart. I'm not up to removing mine to resurrect memory so open it up and tell us what you find.
I actually got mine working using parts from two different antennae so, if yours is all intact, it should be repairable.
bradnree
01-25-2007, 07:51 AM
It appears to be rusted in place also. I have lubed it and will let it set for a while..........Brad
53k
01-25-2007, 04:25 PM
One of my "smarter" moves some years ago was to lube the wind-up antenna on my '53 with a graphite liquid. Can you say "zero radio reception"?
Museum R-4 engine
rockne10
01-26-2007, 08:19 AM
Mine retracts to 6 1/2" and extends to 51".
Brad Johnson
33 Rockne 10
51 commander Starlight
53 Commander Starlight
http://i57.photobucket.com/albums/g233/rockne10/1eb67b4c.jpg
