View Full Version : Installing Avanti sway bar in a Lark-Type
scott.rodgers
11-23-2009, 01:27 PM
I'm installing an Avanti sway bar on my 66 Daytona. I'm working on upper mounts for the links. What angle should the links be at when the car is level on the ground? From pictures I've found on the internet of Avanti installations, the links aren't perpendicular to the sway bar itself (which I assume is parallel to the ground when the car is sitting normally) - it looks like they lean forward.
Scott Rodgers
Los Angeles
SDC Member since 1989
'60 Lark HT
'63 Wagonaire
'66 Frankenbaker
bige
11-23-2009, 01:46 PM
Hope these help:
http://i146.photobucket.com/albums/r241/AvantiR2/swaybar001.jpg
http://i146.photobucket.com/albums/r241/AvantiR2/swaybar002.jpg
http://i146.photobucket.com/albums/r241/AvantiR2/swaybar003.jpg
http://i146.photobucket.com/albums/r241/AvantiR2/swaybar004.jpg
ErnieR
http://i146.photobucket.com/albums/r241/AvantiR2/14w-2-1.jpghttp://i146.photobucket.com/albums/r241/AvantiR2/013-1-1-1.jpg
R2 R5388 @ Macungie 2006 __________________ 1988 "Beater" Avanti
scott.rodgers
11-23-2009, 01:56 PM
Thanks, Ernie - it does. 40 to 45 degrees?
Scott Rodgers
Los Angeles
'60 Lark HT
'63 Wagonaire
'66 Frankenbaker
Alan
11-23-2009, 02:26 PM
Here is a pic. the bracket is 3/16" X 2.75" X 5.5" I can check the angle later.
http://i56.photobucket.com/albums/g171/artcloud/11_23_0.jpg
bige
11-23-2009, 05:43 PM
I'd say that is a good guess.
ErnieR
Scott Rodgers
Los Angeles
'60 Lark HT
'63 Wagonaire
'66 Frankenbaker
