View Full Version : Alternator conversion
3x2stude
11-22-2009, 11:27 AM
I have a 61 Hawk that has a Delco generator. I would like to convert to an alternator and swap out the amp meter for a volt gauge. What is the best path to take? I am planning on swapping out all the old SW gauges with new ones anyway. I will be using a Mallory Unilite from Dave T.
Jon Kammer
52-fan
11-22-2009, 03:15 PM
Have you looked at the technical tips on the SDC page?
http://www.studebakerdriversclub.com/techtips.asp
http://i152.photobucket.com/albums/s186/52-fan/StudebakersofArkansas2-1.jpg"In the heart of Arkansas."
sbca96
11-22-2009, 03:51 PM
You want my Honda swap then, you just need a Stude alt mount bracket.
You can wire the rest yourself pretty much, but I used Lark wiring. It
is on Bob Johnstons site, or here on the forum :
http://www.studebaker-info.org/tech/Alternator/Honda/hondaalt.html
http://forum.studebakerdriversclub.com/topic.asp?TOPIC_ID=8919
http://forum.studebakerdriversclub.com/topic.asp?TOPIC_ID=9241
Tom
'63 Avanti, zinc plated drilled & slotted 03 Mustang Cobra 13" front disc/98 GT rear brakes, 03 Cobra 17" wheels, GM alt, 97 Z28 leather seats, soon: TKO 5-spd, Ported heads w/SST full flow valves, 'R3' 276 cam, Edelbrock AFB Carb, GM HEI distributor, 8.8mm plug wires
rockne10
11-22-2009, 05:15 PM
I converted my '63 Cruiser from the Prestolite alternator to a Delco alternator. The Cruiser is gone but I kept the bracket I had lengthened for the Delco. Yours for postage if you want it.
Brad Johnson
http://s57.photobucket.com/albums/g233/rockne10/Rockne/th_Rocknegauges.jpg'33 Rockne 10, '51 Commander Starlight, '53 Commander Starlight "Désirée"
