When removing the doors we had to drill out the rivets that held the little metal slider straps between the pillar and the door. When re-installing is there a better way than trying to pound new rivets? Has anybody used screws? Nuts and bolts? Does that detract from "originality"? Any suggestions would be appreciated.
Re-installing door "check straps"
I found some clevis pins that were the same as the rivets on the top but have a hole in the other end for a cotter pin. Cotter pin allows them to be removed easily if needed and no risk of a slipped hammer when pounding the rivet.
I linked a picture from the Mcmaster-carr website. You'd probably need to buy a box of them from there if a local hardware store does not have the size. Lots of choices on size.
Jeff in ND
'53 Champion Hardtop
Jeff in ND
I used a button head allen stainless bolt with a nylock, lock nut on it. Works great, and looks good too.
Jim"We can't all be Heroes, Some us just need to stand on the curb and clap as they go by" Will Rogers
As of Veterans Day 2017, IHF has flown 2,450 WWII, Korean, and Vietnam Veterans to Washington DC at NO charge! to see their Memorials!
Found the perfect clevis pins. That will help as we probably have to re and re the doors a few more times to get everything lined up. You guys are the best!Dave Warren (Perry Mason by day, Perry Como by night)
