View Full Version : Master cylinder for hydraulic clutch
3x2stude
11-16-2009, 07:22 PM
I am planning on a five speed trans in my 53 starliner. I will need to add a second master cylinder for the slave. Does anyone have any proven setups for either through the floor pedals or adding a swing type pedal assembly?
mbstude
11-16-2009, 07:25 PM
While I have no experience with this, I have heard of many people using a second brake master cylinder (same one as on the car) and mounting it on the opposite side of the frame rail.
Matthew Burnette
Hazlehurst, GA
11-16-2009, 07:51 PM
I copied the article in a '58 hot rod magazine that told how to put a Chevy in a "late model" Stude.
I Siamesed another brake master cylinder right next to the original one. It lined up perfectly with the clutch linkage. I removed the residual check valve in it. Used longer through bolts to attach both cylinders to the frame rail. I used an 80's Chevy truck bell housing with a built in slave cylinder. I know nothing about hydraulics, but I lucked out and the combination worked perfectly.
Bellingham, WA
http://i706.photobucket.com/albums/ww63/dstnkmp/IMG_7215-1.jpg http://i706.photobucket.com/albums/ww63/dstnkmp/IMG_7216-1.jpg
mbstude
11-16-2009, 08:00 PM
Dick, that makes more sense than mounting it on the other side of the frame rail. (Not sure what I was thinking...) ;)
Matthew Burnette
Hazlehurst, GA
