How does a body man bring out / or tighten sheet metal? The roof has a dip, you can push on this to bring it out, but is there a way to strengthen sheet metal to not be flexible?
roof
It has probably been buckled from someone stepping on it, or storing 'stuff' on it.
A 'good' body man can get the creases out of the buckle.
Eastwood sells a 'shrinking' disc for a hand grinder that will work wonders on it....
But you have to know how to use it...
Bondo is NOT the answer...
Hang in there... You'll get it.
There is a process of heating the metal and then quickly cooling it to make it shrink....though I dont know how to do it. There are websites and probably YouTube videos that demonstrate this technique but you may want to practice on a junk car rather than potentially cause damage to a good car.
Brent's rootbeer racer.
MN iron ore...it does your body good.sigpic
In the middle of MinneSTUDEa.
I would use a mig welder to shrink,not a torch especially on a flat roof panel.depending on the exact situation you can cold shrink the area with a good size socket and a fairly blunt pick hammer.oh and also a good aim!
Joseph R. ZeigerJoseph R. Zeiger
Here's the Eastwood shrinker grinder attachment...
Comes in two sizes...
Here's what they say about it:
(copy)
Metal Shrinking Disk 9in
Item #14050
Only $ 69.99
or
Metal Shrinking Disc 4 1/2 in
Item #29829
Only $ 59.99
Now it's easier than ever to minimize the use of fillers. Eastwood's Shrinking Disc contacts the raised areas to heat & shrink, more accurately than a torch. First clean the surface with an abrasive disc, attach our Stainless Steel Shrinking Disk to your Angle Grinder; spray with soapy water, & move the spinning disc over the damage for a few seconds, spray again with soapy water, then check progress. Repeat if needed then prep & prime. Includes 9" Shrinking Disk & instructions. Made in USA.HTIH (Hope The Info Helps)
