View Full Version : Brake Line Bracket
valleyguy
01-19-2007, 01:39 PM
I'm in the process of replacing the brakes on my hawk, hoses etc as I mentioned on another thread; got the drivers side brakes disassembled and now I'm scratching my head on this brake line bracket. it appears that the line in held on the bracket by a
separate metal piece, but I can't figure how to remove it. It is rather rusty, maybe frozed to the bracket, not sure. Does anyone know how this end of the hose gets removed fromm the braket? ps. note how the steel line is broken. It was really rusty as well and just snapped when I started to remove the fitting. scary..
tks,
http://usera.imagecave.com/jadiggle/Brakes003.jpg
JDP
01-19-2007, 01:54 PM
OK, you need to remove that clip. Start by soaking it with penetrating oil, then tap it on the side to try and get it to rotate on the line, then tap it off the line, or use vise grips to pull it off. (It's "U" shaped with a open end away from the vertical lip.)
64 Commander 2 dr.
63 Avanti R1
63 Daytona convert
63 Lark 2 door
63 Lark 2 door #2
62 Daytona HT/ 4 speed
62 Lark 2 door
62 GT Hawk 4 speed
60 Lark HT
60 Hawk
59 3E truck
52 Starliner
51 Commander
60Lark
01-19-2007, 02:04 PM
The slightly bent piece on the left side of the tab as shown in your pic is/was a clip similar to a C-clip which should pull straight up. If you spray it well with a good penetrating oil such as Kroil and then let it soak for a while, it should loosen the rust up enough to remove the keeper clip, the hose end will then be easily removed. It looks like the clip has rusted enough that it will no longer have any of the flex that it originally had so after the rust is loosed up with the Kroil the clip may come off in pieces.
http://im1.shutterfly.com/procserv/47b6ce20b3127cce8d0e3b50356c00000000400CcNWTlozYsb http://im1.shutterfly.com/procserv/47b6dc03b3127cce970d7aafd15f00000010100CcNWTlozYsb
Studebaker Fever
60 Lark
51 Champion
Phil
Arnold, Missouri
valleyguy
01-19-2007, 08:57 PM
ok, thanks; I'll soak it good and let it sit for a couple of days.
Then we'll see...
tks
01-20-2007, 01:05 PM
Here ya go. I've never seen one that was rusted so bad it had to be soaked. Of course, I don't see many Rust Belt beauties![B)]
http://images.andale.com/f2/115/106/906179/2007/1/20/brakeline.jpg
Miscreant adrift in
the BerStuda Triangle
rockne10
01-20-2007, 06:46 PM
quote:I've never seen one that was rusted so bad it had to be soaked. Of course, I don't see many Rust Belt beauties!
Living in the rust belt, I've seen few that don't need soaked but,
never seen a bracket welded to the frame that has a sheetmetal capscrew holding it on.[}:)] Sorry, Bob, I had to go there.
After the clip and hose are released, you can unscrew the bracket, clean it up and reattach it. Don't unscrew the bracket with the clip and hose attached.
studeclunker
01-21-2007, 12:31 AM
quote:Don't unscrew the bracket with the clip and hose attached.
Rockne, out of curiosity, why? I couldn't get the same clip loose so I just took the whole thing off (via the bolt holding the bracket on). This was because the 4" steel brake line above it broke. This way I was able to remove the fitting and put the new line in. It's a bear to work on (Oi Vay![B)]). Had to fold the fender boot aside to get inside to it.
http://i16.photobucket.com/albums/b18/Studeclunker/studebaby/54wagonblue-2.jpg
Lotsa Larks!
Ron Smith
valleyguy
01-21-2007, 02:08 PM
Mr. Biggs, many thanks for ur trouble in diagraming this removal;
and also tks for all the other good tips. I haven't yet attempted to remove the hose--it's snowing here today so I have other problems to deal with - but I'll get to it soon. I also have included
a pic of the new hose from NAPA; it does have a c-clip and hopefully this will fit in the bracket; Think I might have to modify it as has been suggested? Also the diameter of this new hose is smaller than the stock hose. Does anyone see a problem with that?
tks,
http://usera.imagecave.com/jadiggle/Brakes005.jpg
CHAMP
01-21-2007, 03:05 PM
The newer brake hoses have a smallerO.D. than the older ones did. Shouldn't be any problem, I've had the NAPA hoses on my 48 for nearly a year now.
rockne10
01-21-2007, 08:07 PM
You're right, Ron. I was thinking, with the bracket attached to the frame you can apply leverage to the clip. With it unattached it's all flopping around and you may brake the steel line. If you're replacing the hose and the steel line, why not cut them both , unbolt the bracket and eliminate the contortions. The first time I tried this, I was not planning on replacing the steel line but had to when it broke, which it was probably going to do soon anyway.
farmhawk
01-21-2007, 11:00 PM
Here is a cleaned up picture from another angle.
http://i134.photobucket.com/albums/q90/wkroeger/DrSideFrontWithNewBrakeLines.jpg?t=1169438329
Wayen K.
Libby, MT
61 Hawk (Project)
valleyguy
01-22-2007, 03:51 PM
ok, the thing came apart thanks to your help; it soaked a couple of days and the clip pulled off after some wiggling. the bracket and clip are in better shape than I would have thought... I will reuse
the bracket but I'll replace the clip (as well as the other two when I get to them); Hotwheels63r2, would like to buy the three backets from you; my email is: jadiggle@peoplepc.com. One last question (promise); hate to ask about these basic things, but this is my first time replacing all these parts; I have new wheel cylinders,
ready to install.. they did not come with the metal "push rods"
that engage the shoes... assume I can use the olds ones, but how
are they installed in the new wheel cylinders? (I don't want to mess them usp); do they just push through the rubber boot or do I remove the rubber boot to install them? tks,
http://usera.imagecave.com/jadiggle/Brakes.jpg
JDP
01-22-2007, 04:15 PM
Just pull them out of the old boots, clean them up and reinstall in the new cylinder.
64 Commander 2 dr.
63 Avanti R1
63 Daytona convert
63 Lark 2 door
63 Lark 2 door #2
62 Lark 2 door
62 GT Hawk 4 speed
60 Lark HT
60 Hawk
59 3E truck
52 Starliner
51 Commander
John Kirchhoff
Yes, those little push rods will just push through the boot. If they're corroded and nasty, which they probably are, I like to chuck them into a cordless drill and wrap sandpaper around them as I run the drill. If they're really nasty, I use a wire brush on them first then sandpaper. That way you aren't shoving a rough, cruddy rod through a nice new rubber boot.
