My 289 has good oil pressure, good compression among all cylinders (135 - 140psi) when warm, but I'm afraid it might need a rebuild unless someone has a different way to resolve the oil burning issue. I replaced the valve stem seals (the old seals looked good although the exhaust valve seals were hard) and this didnt help any. I've tried additives and no difference. It smokes most when the engine is cold and clears up after 3 or 4 miles of driving. However, when I drive it at highway speeds (65-70 mph) for up to 125 miles, I need to add a quart of oil. I believe that the faster I drive it, the more oil it consumes. Might this be worn oil rings or worn valve guides? Or other? Thanks for any advice.
Odometer shows 93,XXX miles.
Brent's rootbeer racer.
