My 62 Champ has a 259 v8 with a stand alone center oil filler which has a breather cap. The valve covers also have oil filler caps w/breathers in them. Would there be any harm in putting valve covers on with no oil fillers/breathes in them? I have an extra pair I would like to paint up and put on.
Valve Covers
OR..."clean" up the engine by changing the old fashioned filler pipe to a block-off plate like a '63-'64 engine should have. The only reason you could need that pipe, is to mount an oil filter on it if there is no full-flow underneath, which there probably is! [^]
quote:Originally posted by hotwheels63r2
Yours is probably a full flow block. (oil filter screws on below? )
I'd leave it like it is., but the change can be made.
MIKE
Studebakers Northwest
Ferndale, WAStudeRich
MIKE
There shouldn't be any problem using the cap-less valve covers if it isn't a full flow. If it is a full flow, you need those caps for crankcase venting.
Museum R-4 enginePaul Johnson, Wild and Wonderful West Virginia.
Mel, short answer - YES, you can do that and not have any adverse effects.
Miscreant adrift in
the BerStuda Triangle
Miscreant adrift in
