View Full Version : Need M5 brake pedal
M5Dan
10-18-2009, 12:22 AM
Anybody have M5 parts? I need a brake pedal, also brake pedal shaft, bearing and rod that goes to master cylinder, if possible. Sure would appreciate any leads. Thanks.
garyash
10-18-2009, 10:57 AM
If you can't find the 672593 shaft, here's a drawing. I had one made for my M5 at a local machine shop. I also put some bronze bushings in the pedal arms because they had been worn oversize.
http://www.studegarage.com/images/m5brakes/672593%20pedal%20shaft.pdf
[img=left]http://www.studegarage.com/images/indy/gary_indycar25_vvsm.jpg[/img=left] Gary Ash
Dartmouth, Mass.
'48 M5
'65 Wagonaire Commander
'63 Wagonaire Standard
M5Dan
10-18-2009, 11:07 AM
Thanks, Gary. It good to have the drawing in case I need to have one made. Hopefully I can find one for less.
Dan
jjones
10-18-2009, 11:08 AM
I have a complete pedal assy except for the rod from the brake pedal to the master. (The rod is probably around here someplace but I couldn't find it this morning). Includes both pedals, shaft, chassis mount and brace, and the master cylinder. I have no idea what its worth so make me an offer. It is in good shape with minor wear in the pedals from 80,000 miles of use.
http://i243.photobucket.com/albums/ff17/jeffhelen/DSCF1042.jpg
Jeff Jones
Tucson Arizona
1947 M-5
jjones
10-18-2009, 03:24 PM
I found the brake rod, so have everything you need. Also have a few other misc. parts.
Jeff Jones
Tucson Arizona
1947 M-5
