View Full Version : coil 62 Hawk
dallastx75208
10-17-2009, 06:11 PM
Is there a cross over for a coil for a 62 Hawk. Seems it got thrown away. Did n't know if I coudl get one from the local auto place. Not worried about being stock.
Bud
10-17-2009, 06:17 PM
Most of the larger auto parts houses will have the correct coil in stock for your Hawk. If I remember correctly, the NAPA number is IC17. Bud
dallastx75208
10-17-2009, 06:23 PM
Don't have a NAPA but Auto Zone should have something if it is that common. Thanks, did not know if it was special.
Chucks Stude
10-17-2009, 06:43 PM
NAPA on Harry Hines.
dallastx75208
10-18-2009, 01:47 PM
Is there any way I can talk to you. I am having trouble with wires, where they go. Or if you could take a pic of your fire wall and send it to me. I can not even firure out where the coil bolts down.
Bud
10-18-2009, 07:37 PM
There are a pink and a green wire connected together running along the upper edge of the firewall that connect to the positive or bat. side of the coil. The negative terminal gets the wire from the distributor. The mounting location is on the right rear side of the intake manifold behind the carburetor if the correct manifold is on the engine. Bud
Chucks Stude
10-19-2009, 11:53 AM
Jon, I will take pics this afternoon, and put them on the forum.
Chucks Stude
10-19-2009, 11:08 PM
Wiring pics. The hot-wire going to the electric choke is the overdrive solenoid hot-wire. That wire is part of the wiring harness. If you run the electric choke off of the ignition wiring, than the engine performance suffers. The choke draws a lot of juice.
http://i218.photobucket.com/albums/cc42/Dragasaurus/098.jpg
http://i218.photobucket.com/albums/cc42/Dragasaurus/099.jpg
http://i218.photobucket.com/albums/cc42/Dragasaurus/101.jpg
http://i218.photobucket.com/albums/cc42/Dragasaurus/100.jpg
10-19-2009, 11:24 PM
A stock '62 Hawk does not have a ballast resistor like that pictured. It has a pink resistor wire instead.
Bellingham, WA
http://i706.photobucket.com/albums/ww63/dstnkmp/stude-2-1.jpg
Chucks Stude
10-20-2009, 07:25 AM
I do not remember there being a resistor wire in the wiring harness from Studebaker West. It came pretty much like this.
