I had been noticing erratic behavior with the ammeter in my 54 Land Cruiser. Then the battery was dead and wouldn't hold a charge. I replaced the battery and everything was great except thet the ammeter doesn't show a charge at any time. It does show discharge when the lights are on or the fan or the directionals but no matter how fast the engine is reving, the ammeter won't show a charge.
Ammeter won't show charge
Sometimes, not always, you have to repolarize the generator. This needs to be done when either the generator or the battery has been disconnected.
This involves striking the B and G terminals on the voltage regulator briefly with a wire. It sorta "gets its attention". Do it with the engine off.
Without doing this, the generator isn't generating.
Tom Bredehoft
....On the road, again....
'05 Legacy Ltd Wagon
All Indiana built cars
The Shop Manual will provide a complete diagnosis, but as a first step, I would check your generator to determine its output.
<h5>Mark
'57 Transtar Deluxe
Vancouver Island Chapter
Mark Hayden
'66 Commander
You may not see a charge rate on a new fully charged battery.
A check with a volt meter would verify that the charging system is working as it should. 14 volts or thereabouts when the engine is running maeans everything is OK. The AMP meter is a rate of charge indicator and if no charge is needed, no + reading.
You probably don't have a problem, at all.
ErnieR
Best so far 15.065 @ 91.84 MPH Island Dragway Great Meadows NJ Summer 2009.
Hook it up to the battery...check voltage with the car off and then running. It should read 1-2 volts higher if it's charging OK and lower if it's not.
ErnieR
