Is there a alternator that will bolt up to 62 Hawk without a lot of changes. I thought I had read this but now I can't find it.
generator/alternator swap
A prestolite/autolite and brackets from a 1963 or 1964 Hawk or Lark should bolt right up. My 63 Hawk had been modified to a late model Delco when I bought the car, but the homemade bracket that attached it made the pulleys not run parallel and therefor ruined the waterpump. So, I "borrowed" the prestolite and brackets from my 1964 Daytona and installed it to the Hawk. However, I am ignorant to any possible changes that may need to be made to the factory wiring harness that you have.
Brent's rootbeer racer.
MN iron ore...it does your body good.sigpic
In the middle of MinneSTUDEa.
You'd also have to get a voltage regulator as used in a 63-64 Stude and then wire it appropriately.
Here's a typical wiring diagram for a '63-64...
Just my 2 cents, but the generator system on a '62 Hawk worked just fine. I can't think of a reason to change to an alternator unless you have added a ton of electrical apparatus (like a powerful stereo system). The trouble and expense is not worth it.
Bellingham, WA
Bellingham, WA
The reason is I am building a daily driver. It will have air and I am switching to electric fans for the radiator. I am worried that the generator will not keep up with the power needed at lower speeds. If I am wrong let me know. I have been reading things are here and that is the message that I am getting.
Bellingham, WA
IMHO, there is not an electric fan that will outflow a stock engine driven fan with a stock shroud under normal driving. If you idle a lot or are stuck in stop and go traffic, maybe. I'd make sure the block is clean and that the rest of the cooling system is in tip top shape and drive it. If you have overheating probs then, I'd ADD an electric fan, but not to REPLACE the engine driven fan.
Bellingham, WA
Bellingham, WA
I have a four blade fan now. Was changing it to a seven blade with a clutch but am told it produces a lot of wind noise which is heard in the car. Just going by what I read on here. I do not know for sure.
Maybe I am over thinking this. Might be the Science Teacher coming out in me.
Bellingham, WA
It probably doesn't matter in a 47 year old 2 door hardtop. They are pretty noisy WITHOUT a fan. If quiet is your goal...Lexus .
Bellingham, WA
Bellingham, WA
