View Full Version : Looking for rear axle parts
00RACER
10-11-2009, 04:47 PM
The items I need are for the 44 axle housing.I need 1560657-19 spline standard axle-case assembly-TT-for 3.90-4.89 or lower gears-or just the case without the guts.
---or---1560446 same as above except for flanged axles with finer spline- and again the assembly or the case without the guts
THANKS
PAUL LAUSCH
buddymander
10-11-2009, 05:18 PM
I have a complete 1957 3.90 TT that I'm going to ebay soon and am wondering; does the 3.90 and lower ring gear take a different carrier that the higher ratios, like 3.54?
00RACER
10-11-2009, 06:22 PM
YES, THE ONE CARRIER IS FROM 3.07 THRU 3.73 AND THE OTHER CARRIER IS FOR 3.90 AND LOWER GEARS(I.E. HIGHER NUMERICAL GEARS)
PAUL LAUSCH
10-11-2009, 11:05 PM
TT Carriers are NSS, "not sold separately" Paul.
00RACER
10-12-2009, 09:11 AM
Yes, Studerich-I do realize that but you do run into circumstances where guys have taken some things apart and have these parts
THANKS
PAUL
DEEPNHOCK
10-12-2009, 09:28 AM
You might try a 4wd shop.
Lot's of Dana44 diff's out there in Jeeps and Blazers.
A good one should have a lot of 'outside the norm' parts.
