View Full Version : fan/shroud clearance
dallastx75208
10-10-2009, 07:04 PM
I am switching my 62 hawk four-blade fan to a 6 or 7 blade fan. I have a fan clutch but not sure what clearance I should have between the tip of the fan blade and the shroud. Has anyone done this, and what fan did you use? It looks like a Mopar off a 318 will fit but not sure.
Chucks Stude
10-10-2009, 08:02 PM
Pics enclosed. This is one loud mutha. I live close to you, if you would give me your address, I will bring my 62 Hawk over and let you look at the setup. My zip is 75209.
http://i218.photobucket.com/albums/cc42/Dragasaurus/DSC02124.jpg
http://i218.photobucket.com/albums/cc42/Dragasaurus/DSC02123.jpg
dallastx75208
10-10-2009, 10:51 PM
What fan or where did you get your fan?
Chucks Stude
10-11-2009, 09:29 AM
Stude vendor. I think it was Dave Tibault. The fan clutch is the one sold by our Stude vendors.
Chucks Stude
10-11-2009, 09:33 AM
The spacer is a stock Stude item, with the center cut out to fit the heavy duty Stude water pump. The studs are regular parts, that had to be cut down to fit. The fan is 17" IIRC.
dallastx75208
10-11-2009, 01:52 PM
Any way to cut down on the loudness?
64V-K7
10-12-2009, 06:06 AM
Hi,
The viscous coupling with a 6 blade fan isn't that objectionable unless your rear axle is numerically high. I had a straight 6 blade on my (3:31) Hawk and it was terrible. When I installed the viscous coupling, it dropped the noise to a very acceptable level.
http://www.studebaker-info.org/7168422/sig2.jpghttp://www.studebaker-info.org/64v2488/sig3.jpghttp://www.studebaker-info.org/0381/sig4.jpg
Bob Johnstone
64 GT Hawk
55 President State Sedan
70 Avanti (R3)
Chucks Stude
10-12-2009, 08:41 AM
Jon,
You need to take a trip to Royce City, out I-30 east, and see Bob Helm. He advertises in Turning Wheel, and has bought a out a lot of old dealerships. He had several tons of parts. He has saved mine, and several other people's bacon over the years. You need to call him at 214-537-0921, after 6:00PM central time. He probably has everything you need.
