I'm getting close to starting my 63 Lark project's rebuilt Stude V8.
Poured in the oil and noticed a one drip per minute leak from the drain plug. I'd used a tad loose-fitting nylon type washer replacing a thin and broken metal one. At the rate I'm going, it might be a week or two before I fire up the engine and my clean stainless (salad) bowl now catching the drips might be 5 quarts full by then.
The plug doesn't tighten. You know that feeling that tells you "I'm stripped" and so I'm leaning towards draining the new oil and covering the bowl in a saran wrap until I can tap the hole and seat a new plug. My plug takes a 7/8" wrench.
I've not had to do this before and am wondering if there's any danger in getting shavings inside the pan? Is it generally tapped to the next size up? Or, since I'm only going to change the oil anyway after the break-in, just deal with it then? WWYD?
Thanks!
Thanks!
