I replaced the coil on the 62 Hawk with a Pertronix 1.5 Ohm Flamethrower Coil. Later I installed a Pertronix Ignitor Ignition System to replace the old point system. The car has run flawlessly, until about a week ago, when I thought that I was having fuel delivery problems. I have a new Edelbrock Performer 500 cfm Carb with electric chock. I am thinking that I have a clogged fuel filter. I check the fuel deliver to the Carb... its flowing quite well. Then I see what appears to be fluid leak from around the coil... I look and see what appears to be oil leaking from the coil. I removed the coil to see what model I had and discovered that there is a 1/8" crack almost completely around the secondary tower! No wonder there was oil leaking from the coil!!
Anyone ever have this happen to them, or know what could have caused it? The engine has not really overheated... perhaps to only about 230-240F., but that should cause such a crack? Could it?
IN the mean time, I have ordered another new PErtronix coil. Assuming its a manufacturing defect, I intend to send it back to PErtronix when I receive the new one. I don't want to experience the crack again... so any ideas what I should look for?
Laisez le bon temps roulez avec un Studebaker
