The shop manual describes the function of the flapper type vent located in the air horn adapter cover as "opens when the engine is not running to prevent the accumulation of gasoline vapor within the air horn adapter assembly". I don't see any information as to how far off of the seat the flapper should be adjusted. Can anyone explain in more detail the function of this flapper valve. It seems that it should be adjusted so that it is very close to the seat so that the air pressure will close it without air pressure escaping. What is the danger if it is fully seated?
1967 Riviera, 1964 Avanti, 1953 Champion, Two Studebaker Gravely tractors
