Looking for a carburetor
  • Looking for a carburetor
    Got a call from a guy who inheirited his Dads
    '62 Hawk GT.289 4-speed car.He needs to
    get it running in 2 weeks as his nephew
    wants to use it in his wedding.Needs a
    correct Stromberg 2bbl carb.I only have 259 carbs
    which would work in a pinch but they are warped.
    Anyone have a rebuildable one or a rebuilt one?
    Mono mind in a stereo world
    259 and 289 Carbs. are exactly the same.
      One from a 318 Chrysler will work, though not correct. They are available from most parts stores. NT
      Neil Thornton
      Hazlehurst, GA
      '57 Silver Hawk
      '56 Sky Hawk
      '51 2R16 dump truck
      Many others.
      Neil Thornton
        I have one but can't post pics here email me direct and I will send you a picture.
        dpearson@scwcompanies.com
        I'll send you the pic and when you get it call me and I can give you any other info off of it you might need.
        Thanks,
        Dean.
        (760)802-6460
          Thanks,
          Dean.
          (760)802-6460
            Does it look like this?
              I have one I took off my GT to put on a 4bbl.it ran greatemail me if you are interested,very reasonable
                Yes Rich,mine do look like that except they all
                have about a 1/8 gap between top and bottom at the
                gasket in the top pic.Oddly enough all 3 carbs are
                warped in the same spot.If the carbs are all the same
                what do the different carb numbers mean? There are 6-127
                through 6-132 i.d. numbers in the books.Makes no difference
                to me as long as they work.
                BTW...a local chapter member stepped up and I can call the
                guy tomorrow and he can pick up his carb.Another Studebaker
                will be in a wedding!
                  As the '59-'64 Chassis Parts Catalog will tell you, the 6-127 thru 6-132 are YEAR MODELS! 6-132 is a 1964, 6-130 is a 1963 etc. Since the same Repair kit fits all of the "High Choke" and the other kit fits all of the "Low Choke" models the difference is very slight.
                    A rochester two barrel from a gm car will fit the openings and bolt pattern.
                      The Rochester won't work on the Studebaker manifold without a spacer block. The linkage hangs up.
                      Home of the famous Mr. Ed!
                      Ron Smith
                      Ron Smith
