View Full Version : pinion gear
bing kunzig
01-10-2007, 06:15 PM
Where does one find a pinion gear for a silver hawk? I think it's # 537566. I've tried several vendors-no luck.
01-10-2007, 06:45 PM
If the pinion gear is broken, chances are you need a ring gear also. Try these guys...
http://www.drivetrain.com/
http://farm1.static.flickr.com/145/349983495_04ce12e967_m.jpg
Bellingham, WA
bing kunzig
01-10-2007, 07:11 PM
Sorry I was vague. It's the speedo pinion gear.
01-11-2007, 11:35 AM
There's a problem with what you're asking here. That part # (537566) is a pinion gear for a car fitted with the Studebaker (Detriot Gear) Automatic (1955 V8 and earlier car). A Silver Hawk wouldn't have such a tranny unless someone had gone to the trouble to transplant one into it.
Miscreant adrift in
the BerStuda Triangle
53k
01-11-2007, 02:16 PM
I think most of the major vendors have them. You will need to know the rear end ratio as that determines both the pinion and speedometer gear part numbers.
Museum R-4 engine
bing kunzig
01-12-2007, 11:46 AM
Here's how I arrived at the part #. The car is a '57 Silver Hawk. The parts manual covers '55-'58.In the speedometer gear and pinion chart it lists model 16G8 (that's mine I think) with an axel ratio of3.31 (that's me again) with automatic requires a pinion gear # 537566. If I have calculated this incorectly please advise.
55studeman
01-12-2007, 12:21 PM
Model 16G8 is for 55 president with V8, hence the wrong year -wrong tranny. Check the model codes at the front of the chassis manual. The listing is kinda hard to follow, took me a while to get it down.
oops, as Mr. Biggs says Commander not President, I knew that.
E. West
"The Speedster Kid"
Sunny Northern California
Where the roads don't freeze over and the heat doesn't kill you.
And an open road is yours to have -only during non-commute rush hours 9am-4pm and 7pm to 7am (Ha, ha, ha)
01-12-2007, 04:28 PM
You need to look at your car's body tag. As the kid's said, 16G8 is a 55 Commander. Your car would be a 57H 57 indicating the year, "H" indicating a President-series car, or more to the point, a car with a 289cu.in. engine.:D
Miscreant adrift in
