Brake question
Are you loosing fluid? How long will brake pedal remain firm with
steady pressure? I think you have a problem with your master cylinder, any sign of water contamination? How much crud did you
clean out? More questions than answers but don't have enough
information to say anything other than master cylinder. I would
check again for debris, I think that could be your problem
Karnak the Magnificient says...I see a master cylinder rebuild in your future.
Or a new one. Either way, I'd get to it pronto! If the old one isn't pitted you can use a hone and just re-build it. It isn't hard, just follow the shop manual. You do have one, of course? Glad you got the universal joint issue figured out...Russ Farris1963 GT Hawk R-2 4-speed
1964 Avanti R-1 Auto
A new MC is in order. They are inexpensive. Check e-bay. Less than 40 bucks. jimmijim
Stude Junkie+++++++Do it right the f$$$$ Time. Never mind. Just do it right. When youre done your done. You'll know it.sigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
As the others stated: probable bad master cylinder.
IF the pedal sinks slowly AFTER you pump it a few times and hold it,Then you need a new master cylinder.
However- IF the pedal is hard and firm after "pumping them up".. you need to adjust your shoes.
As the shoes wear- if the "self adjusters" aren't quite working properly, you get too much distance between the shoe and the drum. As you push the pedal down, you don't have enough fluid volume to press the shoes all the way to the drum. So, you have an inconsistent first push.
If your shoes are properly adjusted, the pedal shouldn't get more than 1/3rd of the way to the floor before getting hard.
If the pedal gets too close to the floor, the internal piston opens (uncovers) the pressure return bypass hole- and you have NO pedal at all, and the pedal sinks rapidly.
I would check my shoe adjustment FIRST- before swapping the cylinder.
Ray
Ray
www.raylinrestoration.com
