From what I can find the 1950 champion with manual trans and OD did not come with turn signals but that it was an option. Some one has put an after market turn signal hose clamped to the steering column of my car and I would like to get rid of it. My question is in Texas can I just take it off and tell the person inspecting my car that this car did not come with turn signals or do I have to have them and if so were can I get the original setup for my car? Thanks
1950 turn signals
You should be okay in Texas...especially if you have historic plates.
I never had any problems with my old car there.
63 Avanti R1 2788
1914 Stutz Bearcat
(George Barris replica)
Washington State63 Avanti R1 2788
1914 Stutz Bearcat
Washington State
My only question is - Why would someone want to drive around in today's traffic without turn signals? At a safety check you may pass, but if you are involved in an accident and found to be at fault because you didn't signal, you could have a lot of problems. Also, young people driving today probably wouldn't have a clue as to what your arm signals mean. I would fix them so they work, but that's just me.
1950 Champion 9G F1
My "50 Champion came from the factory pre-wired for turn signals, even though it did not come with the signals installed. It is my understanding all 50's came pre-wired from the factory. I purchased an after market switch at a swap meet and installed it in my 50 Champion and it self cancels, and works great. You can tell if your car is pre-wired by removing the rear tail light lense. If its prewired, there will be an extra light socket in the housing for the turn signal bulb.
They sure look like they were installed at the factory. Is this what the dealer-installed unit looks like? I seriously doubt that the woman who bought my car new installed them herself but I would think that the dealer would install them if asked....
1950 Champion 2 Dr. Sedan
1949 Studebaker 2R5 half ton pickup...
Dealer or Factory installed - they would look like that. They were an option in 1950. Everyone knew hand signals back then and there were LOTSA cars from the 30s still running around with only one taillight.[:0]
Jim, if you've got sure enough Studebaker turn signals on your 52, they're supposed to self cancel. Same with the 1950 edition. There's supposed to be a little tab that fits to the steering sector shaft that actuates the TS switch to cancel it. Maybe you're missing that piece.[^]
1963 Cruiser
1957 President two door
