View Full Version : Transmission Number
Rob
01-06-2007, 11:26 PM
On my 3 speed Overdrive where is the I.D number so I can verify the year. My car is a 51` but my motor is a 62` 259. thanks
JDP
01-06-2007, 11:43 PM
Cast in the side of the case, i.e. T-86
http://stude.com/sig.jpg
JDP
Arnold Md.
Studebaker On The Net
http://stude.com
My Ebay Items
http://www.stude.com/EBAY/
64 GT hawk
64 Commander 2 dr.
63 Avanti R1
63 Daytona convert
63 Lark 2 door
63 Lark 2 door #2
62 Lark 2 door
60 Hawk
59 3E truck
52 Starliner
51 Commander
Rob
01-07-2007, 12:02 AM
Cast # T86E-1A
Stamped # K41-3
JDP
01-07-2007, 12:13 AM
JDP
Arnold Md.
http://stude.com
My Ebay Items
64 GT hawk
64 Commander 2 dr.
63 Avanti R1
63 Daytona convert
63 Lark 2 door
63 Lark 2 door #2
62 Lark 2 door
60 Hawk
59 3E truck
52 Starliner
51 Commander
Rob
01-07-2007, 12:16 AM
I went back out in the garage and looked and the stamped # is K41-3. It`s not a slide in, and it is a short tail. Thanks
Dwain G.
01-07-2007, 11:49 PM
Looks to me like October 4th, 1951, 3rd shift:
http://home.comcast.net/~jdwain/trans.date.jpg
http://home.comcast.net/~jdwain/63.63.jpg
Dwain G.
Rob
01-08-2007, 12:28 AM
Thanks for the info. Dwain G.
Does anyone have any info. on the rear end.
01-09-2007, 02:41 AM
Well; we can't tell you what you have, since it's a home-built car. But I can tell you what it COULD be, and where to look to verify it.
On the back side of the diff. housing, lower right side there is a web between the "pumpkin" and the axle tube. On that there should be a raised # in the casting. It should be a "44", if this '51 is a Commander but could be a "23", or "27" they are all Dana/Spicer tapered axle rear ends, the later are for lightweight low powered cars. The ratio should stamped be on a tin tag under a bolt on the rear cover, usually at about 7 or 8:00 (under left lower bolt).
Studebakers Northwest
Ferndale, WA
Rob
01-10-2007, 06:17 PM
On the rear end The cast# is 2018 188. On the tin tag # is W 50-11.
Rob
tbredehoft
01-10-2007, 06:35 PM
50-11, 50 divided by 11 equals 4.5454. That's usually called 4.54 or 4.55, makes a 232 pretty quick, runs a larger engine too fast.
Tom Bredehoft
'53 Commander Coupe
'60 Lark VI
'05 Legacy Ltd Wagon
Rob
01-10-2007, 07:08 PM
My `51 Commander has a `62 259. I plan on building it up some. It should be a pretty quick car to cruise around town in, with 4.55 gears
Is this a Dana 44
Rob
01-10-2007, 10:46 PM
Is this a Dana 44
Can't tell until you post the answer to Rich's question...
"Well; we can't tell you what you have, since it's a home-built car. But I can tell you what it COULD be, and where to look to verify it.
http://farm1.static.flickr.com/145/349983495_04ce12e967_m.jpg
Bellingham, WA
Rob
01-10-2007, 11:00 PM
It is a `51 Commander The cast# that I found on the rear end is 2018 188.
Rob
01-10-2007, 11:22 PM
There will be a 44, a 23, or a 27 in the web between the right axle and the pumpkin. This will tell which Dana rear end it is...
http://farm1.static.flickr.com/149/353462730_371fd22f32_b.jpg
Bellingham, WA
Rob
01-10-2007, 11:51 PM
Thanks , I`ll go out to the garage and check.
It`s a 44.
This is a great site for Stude info. Thanks guys
Rob
