I'm using PPG's OMNI bc/cc to shoot my 63 sedan project. Do I have to shoot the cc immediately after the base coats, or can I wait, say, 24 hours? I'd like to get another gun for the cc and don't want to make the long trip to get it now. Thanks.
Base/Clear coat question
Tom
PPG says the maximum time to clear coat is 24 hours. I'd guess if you were close to it it would probably be OK.
DISCLAIMER - While I've used Omni on occassion, I've never waited more than an hour or so.
ADVICE - If you have not sprayed Omni before, be careful of how heavy you lay the coats down. The first time I sprayed it I put it down like older acrylics and lost a couple of areas to runs. Luckily it had hardner so I sanded them out after 3 days and put a little less on per pass. Layed down well with no zips, runs or errors.
It looks quite good with little orange peel if you spray it correctly.
Bob
