clunk noise
quote:Originally posted by bams50
I'm thinking universal joints, worn spring bushings, or shock bushings.
Parish, central NY 13131
SDC member since 1975John Clary
What about checking the fluid in the Transmission. Also the rear end well it wouldn't hurt to check all of the fluids. A good lube job and you should be able to see the problem.
Mabel 1949 Champion
Hawk 1957 Silverhawk
Gus 1958 Transtar
The Prez 1955 President State
Blu 1957 Golden Hawk
Daisy 1954 Commander Regal Coupe
Fresno,Ca
Mabel 1949 Champion
Gus 1958 Transtar
Fresno,Ca
I had exactly the same clunk in my GT Hawk on a road trip to Key West 20 years ago - the nuts holding the universal joint to the drive shaft, I forget which end, had loosened. Go down the road at 15 mph or so, then shift into neutral - not under load, if it's loose, you'll hear the drive shaft flopping around. Russ Farris1963 GT Hawk R-2 4-speed
1964 Avanti R-1 Auto
My guess is one or two worn universal joints. You have been greasing them, haven't you? Even with grease, they wear out. Not a big deal to replace them.
Studebaker enthusiast much longerGary L.
I bought the U-joints today to install tomorrow. I figure just to change both of them even if it's just one that is bad. The drive shaft has a slight wiggle to it if I grip it and try to turn it back and forth. I did not check to see if bolts were lose though, sinc I can't fit under it without a jack. Thanks for the help everyone...
-Chris
1964 Daytona
Seattle,Wa
LOTS easier changine U-joints at home versus on the side of the road.
Paul
Winston-Salem, NC
Visit The NEW Studebaker Skytop Registry website at: www.studebakerskytop.comPaul
Winston-Salem, NC
Check out my YouTube channel here: https://www.youtube.com/user/r1lark
