View Full Version : Under Hood Brake Resevoir GT Hawk
CKOT
01-05-2007, 12:23 PM
I have a '63 GT Hawk with manual/drum brakes. Someone told me I could get a remote resevoir to avoid having to add/check brake fluid via the driver floorboards. Is this possible, and if so, really worthwhile? I am not completely averse to checking/filling via the floorboard opening, but probably be easier under the hood. Thanks for your inputs/answers/ideas.
http://f3.yahoofs.com/users/4278c8ebzfdf9735f/3146re2/__sr_/70fare2.jpg?ph4WVnFBaY_cpsvw
Chris Kot
63 GT Hawk
37 Dictator
01-05-2007, 12:33 PM
The disc brake Hawks came with the remote fill reservoir. Here is the one in my '63 (it should be painted black and have the proper fluid warning decal, BTW)
http://farm1.static.flickr.com/134/346790078_ecbf867316.jpg
Of course the cap on the M/C is different also to accept the line from this reservoir.
I would guess that these may be hard to come by. They didn't make many '63-64 Hawks...and only a portion of them with the power disc brakes. The Larks and Avanti's had the firewall mounted M/C.
There are plenty of aftermarket ones around, however, for the hot rod market.
http://farm1.static.flickr.com/159/344438331_34aef71cb0_m.jpg
Bellingham, WA
CKOT
01-05-2007, 01:00 PM
I actually have one, came with the car when I got it 3 years ago, was in the trunk. Finally getting around to thinking about, which prompted this posting. Now to see if it is worthwhile or not. I guess I will toy around with what it would be like having it under the hood. I check it a few times a year, and flush it every spring, so may be easier. I have the bracket as well, would just need to get the proper cap, and the line.
Chris Kot
63 GT Hawk
37 Dictator
klifton1
01-05-2007, 01:52 PM
I think you can still get the cap from SASCO. That is where I got mine.
Klif
55 Speedster
42 Champ Coupe
starlightchamp
01-05-2007, 02:16 PM
The cap on the master brake cylinder is special in that it has a right
angle brass fitting to accept tubing from the firewall reservoir. Also it
is a metal cap that must be threaded into the MC. I had to use plumbers
tape on the threads to stop leaks. The firewall reservoir was added on
disk brake cars to increase the supply of fluid they require.
1950 Champion Starlight
1963 Hawk GT
Santa Barbara
CA
JDP
01-05-2007, 06:08 PM
It was only used on disk brake cars because they need more fluid storage to fill the four front calipers.
http://stude.com/sig.jpg
JDP
Arnold Md.
Studebaker On The Net
http://stude.com
My Ebay Items
http://www.stude.com/EBAY/
64 GT hawk
64 Commander 2 dr.
63 Avanti R1
63 Daytona convert
63 Lark 2 door
63 Lark 2 door #2
62 Lark 2 door
60 Hawk
59 3E truck
52 Starliner
51 Commander
53k
01-07-2007, 08:41 AM
The disc brake Hawks came with the remote fill reservoir. ...
The '60 Hawk I bought from England a few years ago had the disk brake reservoir installed. I guess the previous owner got tired of checking the under-floor master cylinder. The car also had a Tele-lube automatic chassis lube system installed. A Tele-lube had a 30-weight engine oil reservoir and a pump that injected oil into all the grease fittings whenever the engine was started (talk about Studebaker oil leaks).
I sold the car to a funny little fellow who wanted to replace his 365,000-mile '60 Hawk that was so rusted it was a wonder it didn't disentegrate on the road. Anyhow, he brought the car back to me for something. It required a lift so I took the car a couple blocks down the street and had a little garage do it. As an aside, I told them to add some oil to the Tele-lube reservoir. Guess to which reservoir they added the oil. Hint- brakes don't work well with engine oil. The garage did make good- re-did his whole brake system at no charge.
Museum R-4 engine
