View Full Version : Dormant transmission
ISpy
07-25-2009, 12:53 PM
I have a 59 Lark 6/auto that was stored in a barn and not driven for 25 years...Motor has been cranked up and is basically running well.
Trans seems to have been sitting filled with fluid,fluid appears fresh/normal. I would like to make sure before I put it under load I have done what I can to give the best shot a living...that is an $$s part !
This would have been down the road but the pace where I dropped it they need to move it. I dont want to muck it up but I would need to go help (an hour away) if it cant be moved under its power.
N8N
07-25-2009, 01:10 PM
I'd just change the fluid, clean the screen, adjust the bands and drive. Not much else you can do, and if there's nothing wrong with it, that's all you need to do. If there *is* something wrong with it that hasn't shown itself yet, you won't know until you start driving it anyway.
If it only needs to move "around the block" and the old fluid appears uncontaminated, it should be fine as is, again, unless there's a problem that hasn't been identified yet.
Warren Webb
07-25-2009, 04:00 PM
Why not put jack stands under the rear axle & run it thru the gears first? True it wont be the same as driving it, but the no-load initial run would be easy on the mechanicals & loosen anything that might otherwise be tight & fail.
60 Lark convertible
61 Champ
62 Daytona convertible
63 G.T. R-2,4 speed
63 Avanti (2)
66 Daytona Sport Sedan
buddymander
07-25-2009, 05:16 PM
Make darn sure that you check the transmission fluid LEVEL in the CORRECT manner. Then just drive it. Isn't your transmission one that has to be checked in DRIVE with the engine running? Have fun with that procedure; it's the ONLY way.
