View Full Version : 232 rebuild
Jim Beckman
01-04-2007, 09:46 AM
I've got a 1951 Commander and I've got the engine out of it
and stripped down to the heads and short block. I've never
been this deep into an engine, so I need help with some basic
questions.
First the simple question - if I want to replace some (or all)
of the head bolts, what grade of bolt should I buy? Is it a
good idea to replace them all?
Second, pistons. This is a 232 V8 with nothing obviously
wrong with it except age and use. In looking around at the
main parts sources, I don't find any way to get replacement
pistons for this engine, either standard size or oversize.
So what does this mean for me? What are my options when I
take the block to the machine shop? Am I limited to boring
the minimum amount, and reusing the original pistons with
new standard rings? Can I have it bored and sleeved to standard?
It looks like for other engines I could have it bored as
necessary, and go with oversized pistons. Are there other
places I should be looking for pistons?
This is new territory for me, so I'd be grateful for any advice
from folks who have been there and done that.
Jim Beckman
Leonardo, NJ
01-04-2007, 10:42 AM
Unless the existing bolts are damaged, I'd reuse them. I think you'll have a hard time finding the exact lengths that Studebaker used, and the exact length is critical (too long and some may bottom out, too short and not enough threads will grip properly). SASCO may still have NOS sets.
Fairborn (and others) carry 232 pistons...
http://www.fairbornstudebaker.com/parts.htm
If you bore ANY amount you would have to change pistons. You can often hone and use the same pistons. Have your machinist measure the wear, ridge and taper on the cylinders to determine if you can reuse the existing pistons. You can bore and sleeve to standard, but this is expensive and your existing pistons may not be reusable even in standard holes (they may not be standard pistons...it is possible that this engine has been rebuilt sometime in the past).
If this is your first rebuild, proceed VERY carefully. Read and re-read the shop manual. Find other material on rebuilding engines and study that. Find a good machinist to measure and evaluate parts for you and to advise you along the way. You'll also need him (probably) to resize rods, bore the cylinders, grind the crank, replace valve guides, redo valve seats, etc. etc.
http://farm1.static.flickr.com/132/337488631_093fcbbeec_m.jpg
Bellingham, WA
Guido
01-04-2007, 12:25 PM
One word of advice on the head bolts. While you have it stripped down, I would run a tap into the threads as well as clean up the bolts with a wire wheel. You do not want to have a false reading when you torque them back down or wring the head of the bolt off as I did on a '62 Willys Super Hurricane. After using carbon tipped bits to drill it out to use an easyout, I ended up snapping that off too. Ended up having to resort to carefully burning it out with a torch, something I never want to do again.
http://thumb14.webshots.net/t/53/453/1/21/36/2964121360097493054pVJTFL_th.jpghttp://thumb14.webshots.net/t/57/757/2/88/4/2023288040097493054SEKowB_th.jpghttp://thumb14.webshots.net/t/18/19/8/37/21/2050837210097493054IYBJJL_th.jpghttp://thumb14.webshots.net/t/59/559/1/43/57/2876143570097493054jKVhDw_th.jpghttp://thumb14.webshots.net/t/22/22/0/2/68/2589002680097493054ftBuBw_th.jpghttp://thumb14.webshots.net/t/28/28/8/30/30/2075830300097493054aSSlFv_th.jpghttp://thumb14.webshots.net/t/59/459/2/23/86/2067223860097493054YoeGMx_th.jpghttp://thumb14.webshots.net/t/28/28/5/18/33/2537518330097493054OgEKcN_th.jpg
Chicken Hawk
01-04-2007, 04:34 PM
You can bore it .187" from 3 3/8" to 3 9/16" (259 size)and use standard 259 pistons if you want. I have two sets of heads; one standard and the other export that are 7.5 compression in case you are iterested. Very cheap. Shipping would be more than the heads.
If you are interested in pepping it up a little you should go the 259 route and you can put the '55 and later heads on if you wanted to. Also you can mill any of the heads .060" or more to raise the compression. If this interests you, you can also putin an R 1 cam.
Ted
questions.
Jim Beckman
Leonardo, NJ
John Kirchhoff
01-04-2007, 04:42 PM
Your job is one that you never want to automatically assume anything on. I don't know how many miles it has on it, but mine had 86k and the cylinders werestill within specs as were the main bearings. The rod bearings were still sevicable but they aren't that expensive, so I replaced them. I put in new rings. The most worn item was the valve stem guides, I had them knurled when I had the valves ground because they weren't worn badly enough to replace.
Cylinders will wear barrel shaped, so you need the right measuring equipment. One clue to cylinder wear is to feel how deep the ridge at the top of the cylinder is worn. If there's a noticable ridge, the middle of the cylinders are probably pretty worn. If not, a simple honing and new rings may do the job adequately. When you put new rings on any used piston, make sure the ring land is cleaned of carbon or you can but a ring then it reaches the worn spot on the cylinder at top dead center. Better mike every journal on the crankshaft, tools were made that would turn a journal with the engine intact and in the car. On those jobs they would usually turn only the bad journal. Get some plastiguage from an auto parts store to determine bearing clearance, the main bearings may be just fine, mine were. If any of the insert bearing have some copper or God forbid, steel showing, it's definately new bearing time. If you want to check things yourself, a set of 3 Chinese micrometers are $40 and telescopic guages $15-$20. With those you can measure everything but the piston, for the pistons, accurate Chinese vernier calipers are $20. Unless the pistons are visabaly scored and the cylinders quite worn, they're probably fine. You guys out there can laugh all you want, but I hate to admit it, that sort of Chinese tools are pretty accurate, or at least accurate enough. Should measure the parts yourself, myself or others here can tell you how and what to check.
01-04-2007, 11:12 PM
Two suggestions:
1. Have someone who really knows engines to look at it for you. Five minutes and he can tell you what you've got.
2. Unless this is a concours-numbers-matching restoration, 259" engines are still a dime-a-dozen. Don't bother to re-bore and rebuild your 232", just start with the best 259" you can find.
thnx, jv.
John Kirchhoff
01-05-2007, 10:12 AM
jv had a very good suggestion. Giving someone knowledgeable $20 or taking them to lunch would probably be money well spent. You know the old saying "You can't see the forest for the trees'? Well jv should be commended for seeing the forest where I saw trees.
Jim Beckman
01-05-2007, 03:24 PM
Hey, you guys are great! Thanks for the advice. I figured if I
could just ask in the right place, I'd find the experts.
The engine I've got pretty definitely isn't original to the car.
The car is a 1951, but the engine is a later one. For one thing,
it has the Stromberg WW carburetor on it. And the serial number
on the block is up front, by the fuel pump, not back by the
distributor. The serial number on the block is 527644.
I've got the shop manual for 1951, and the chassis parts catalog
for 1951 thru 1954. It looks like that serial number may be out
of the range those cover. Any idea what I've really got here?
I've measured the bore and stroke at 3-3/8 by 3-1/4 using a
vernier caliper, best I could manage.
There's a small ridge at the top of the cylinders. I'm not sure
I could get the pistons out without taking it off, and I don't
have the tool to do that, plus I don't have the experience or
the tools to measure the cylinder bore properly. I was thinking
of taking the block to a machine shop, and have them cut the
ridges off, remove the pistons, measure the cylinders, and tell
me what the numbers are, so we could decide how to proceed.
Plus they could clean the block up and inspect it better than
I could myself.
Maybe it's worth it for me to buy the tools myself and learn
to do the measuring? This is supposed to be an educational
experience, and I'm not really in a hurry. Somehow all the
measuring to figure out how the cylinders are worn seems like
magic, but I suppose it isn't.
Again, thanks for all the advice, I'm learning a lot.
Jim Beckman
01-05-2007, 06:03 PM
Hi, Jim,
Learning is good. Tools are good. Enjoy the experience. However, understand, when you are done learning, the block is still going to wind up in a machine shop and they are going to measure it all again.
Back in the bad old days, your block would have been given a quick hone, the pistons would have been knurled and thrown back together with some new rings, valve job, knurl the valve guides and ready to run another 50KMI. Probably cost you $200 in 1959.
thnx, jv.
01-05-2007, 08:58 PM
Jim, Without a "V" or some letter as a prefix, that engine number you give is not an engine number. CASTING number maybe, but not an engine number.:)
Miscreant adrift in
the BerStuda Triangle
Jim Beckman
01-08-2007, 08:36 AM
[quote]Originally posted by Mr.Biggs
Aha! I should have known that a number obviously cast into the
block wasn't the serial number. So a little solvent and some
more elbow grease brought up the serial number back by the
distributor pad where it should be: V79115 which is reasonable
for being the original 232 engine in this car. I was also wrong
about the carburetor. Careful reading of the chassis parts
manual shows me that the Stromberg WW is correct and original.
Well, I said this was supposed to be a learning experience,
and I'm making progress.
It also dawned on me that I can get a pretty good idea of the
condition of the cylinders just by measuring each of them
with the pistons at the bottom of their stroke. So I'm going
to get the tools and try that. One remaining mystery is
whether or not this engine has been reworked previously.
I can see that the bolt on the front of the drive shaft has
been removed once previously, since it has a big notch where
somebody used the "cold chisel" method to get it started.
So I figure to make some measurements of the cylinder bores,
take a look at the bearing inserts for wear, and probably
measure the crank journals. Then I might have a reasonable
idea what sort of rebuild is needed before I go talk to
a machine shop.
Again, thanks for the help and advice.
Jim Beckman
Leonardo, NJ
1951 Commander Starlight
