flat head engine questions
  • flat head engine questions
    For the six cylinder flat head engines; if they have been sitting long, what is the best way to lubercate them to get them to spin fast enough to start?
    I heard everything form Marvel Mystery oil to diesel.(sp)
    Please advise on lubrecant and procedure.
    Thanks
    David G. Nittler
    David G. Nittler
    David, everyone has their 'favorite'. For this application, I like Marvel Mystery oil, but that's just me. My theory (unsubstantiated) is that the thinner mixture seeps in around the rings/lands.
    Pour an ounce or so in each cylinder, let it sit a couple of hours, turn the engine over about two turns by hand (with plugs out). Repeat procedure. If you spin it with the starter and the plugs out, you may end up with a mess<G>.
    There probably is no 'wrong' way to do this........
    Paul
    Winston-Salem, NC
    Visit The NEW Studebaker Skytop Registry website at: www.studebakerskytop.com
    Paul
    Winston-Salem, NC
      You can pour a small amount of Marvel Mystery Oil or ATF into each spark plug hole and use a squirt oil can through a hose attached to an 1/8th inch pipe plug in one of the pipe fittings on the right side of the block to pressurize the oil system. Bud
        Thanks one and all. I'll try it.
        David G. Nittler
        David G. Nittler
          Diesel works well, too - but the engine will smoke on startup.
          Chris Pile
          Editor: The Studebaker Special
            Marvel works good, and smells good, too. KP
            Ken Pyle
