I've had my 64 Daytona for 2 years and I'm finally getting a chance to fix the overdrive. Its been in low range (normal) all this time. The cable is hooked up and forward. The kickdown fuse is good and I bugged out all the wiring and is ok. With key on, voltage to one side of governor. When I jumper the governor, the solenoid clicks per the shop manual troubleshooting guide. The book says probably a bad governor......
I would like to try to put a toggle switch in to jumper the governor to test it on the road. Should be no issue with this,,,,right???
Might even leave it there for this summer till I tear it down this winter for more detailing. The toggle switch would simulate the governor kicking in at 25 to 30 miles per hour manually, without the governor accually working. Comments or experiences that help me???Thanks, Greg
greg hellmuth
greg hellmuth
