As most of you know, I have antennas on my mind. I need to find a local machine shop in Sacramento,Ca. They got to have a CNC Screw Machine. I need to reproduce the retainer nut that is used on the studebaker antennas. It is made out of brass and then it must be sent out to chrome. I need 50 retainer nuts to be made. Any suggestions.
Need to find a local Machine Shop
Sal, I thought of that but there will be a material miss match. Since the tube that hold the mast is made of brass, you will have a expansion miss match. The stainless vs brass could be a big problem when it gets hot or cold .
quote:Sal, I thought of that but there will be a material miss match. Since the tube that hold the mast is made of brass, you will have a expansion miss match. The stainless vs brass could be a big problem when it gets hot or cold .
The machinist who did my project is backed up right now, but if you wanted to send a sample, I'd show it to him, get an estimate of time and cost and return it promptly to you.
thnx, jack vines
PackardV8PackardV8
