6 volt battery cable size
  • 6 volt battery cable size
    I need to make new battery cables and would like to know the proper size wire to use. The car is 6 volts (51 Champion 6 cylinder). Thanks for your help.
    Don
    2 gauge is the smallest size cable that I would use. 1 or 0 would be better. Bud
      Go to a tractor supply and buy 00 cables (double odd they are called)
      Autozone has 0 ( called odd) cables ready to go also but much more expensive.
        thanks for the help.
        Don
          I made my own from 00 welding cable, run the ground to a starter bolt
          Jim
          their Memorials!
            kindly submitted, aught not odd.
            '50 Champion, 1 family owner
