Would other carbs fit on the 259 -4 barrel?
Will other carbs fit on 259 -4 barrel manifold
In a word, yes.
WCFB will bolt on a Stude WCFB intake.
An AFB will bolt on a Stude WCFB intake if:
(a) You machine the secondary bores to clear the AFB secondary butterflies.
Or.....
(b) You put a heat insulator gasket stack on there...
Or....
(c) You run a carb adapter.
And...
You will need to do some minor linkage modifications to get it to work.
An AFB will bolt to a Stude AFB intake manifold.
(You will need to do some minor modifications to get the linkage to fit properly)
An old Autolite will bolt up...if you can find a decent one.
There's a new Holley out that is supposed to compete with the Edelbrock AFB that should also bolt on.
The new Holley is 600cfm, which 'might' be a tad on the large size for a stocker 259.
Why do you ask?
Just curious...
quote:Originally posted by 14x7
Would other carbs fit on the 259 -4 barrel?HTIH (Hope The Info Helps)
Just went through this.
Found the thread with a simple search:
Parish, central NY 13131
I must have missed it, but I didn't see where it said if a Rochester 4 jet has the same bolt pattern as a WCFB.
StudeRichStudeRich
quote:Originally posted by Hippie
GM used both the WCFB and 4 Jet on the same intake manifolds for years.
Yes they are the same bolt pattern, and they work fine on the Stude. WCFB Manifold, I have run one on a '57 Intake.
Bellingham, WA
Bellingham, WA
