Would someone have a drivers door for my 59 Lark Wagon. The door is unique to the wagon. Regards Mark
59 Lark Wagon Drivers Door
IS the 59 wagon door like the 56 wagon door. The difference between the 56 wagon and 56 sedan door is just the roofline section. I took a NOS 56 sedan door and cut the top off my old wagon door and fit them together and it worked fine. Check with SASCO Denise can tell you if that is the only diff. If so not a big job to make work. Good Luck!!
Yes I didn't think that I had to mention that the 59 wagons were only 2 door. The 56 sedan door or any other 2 door sedan will not fit the wagon. I wanted to avoid grafting whats remaining of my orginal door to the new sedan door that I received from Sasco. Sasco does not have any drivers wagon doors but some passenger doors. Thanks Candbstudebakers and KGlowacky. If possible candbstudebakers see if you might have an unrusted one. I don't imgaine that sending it Greyhound to Ferndale Wa would be that much. Regards Mark
