View Full Version : best method to clean an old fuel line ??
bradnree
12-29-2006, 10:26 PM
I am redoing a '52 Commander and I need to clean or replace the fuel line. What is the best method for really cleaning an old fuel line ??......Brad
12-29-2006, 10:37 PM
Personally, if there's any doubt (that is you can see it's crushed, worn or crusty-rusty) I'd replace it. If it looks faily decent, compressed air's about as good as anything. Then use an in-line filter, just before the fuel pump.:)
Miscreant adrift in
the BerStuda Triangle
Rosstude
12-29-2006, 10:47 PM
Shoot carb cleaner through, let it sit, repeat several times, follow with compressed air.
[img=left]http://i52.photobucket.com/albums/g27/Rosstude/11-27-061.jpg[/img=left]
Ross.
Riverside, Ca.
1957 Provincial X2
1958 Transtar
whacker
12-30-2006, 12:14 AM
For as much trouble as it is, you should just replace the line. Saves a lot of headaches later, doesn't cost much, and isn't hard to do.
