I pulled the starter. Opened it up Looked at all the parts inside determined that most everything was in good shape. Springs held the brushes tight. The brushes Looked darn near new. I Cleaned the connections on all the electrical parts. Inspected the Bushings on either end not a scratch or wear mark. I replaced the Solenoid and now it is just turned over Just fine, twice, once in the drive way, once a few days later, and now it's stuck at the local coffee shop a waiting my getting it started again.
I took it out of gear and shorted the connectors on the solenoid it turns better if I do that to get it started than with the switch.
It barely turns the engine over. I'm going to check out the battery next. Just in case I missed the obvious.
I'm going to check the new switch it has for a bad connection.
Double check the connection in the starter.
If all else fails I have a rebuild kit I will just start all over again and put that all in it. Looking good or not.
is there any other thing to check out that I might be missing?
Owner of a 1950 4 door Commander
I'll Tattoo you anytime!
you can find me at
Lucky Linda's Body Art 952-445-3281
18 years in the tattooing biz
you can find me at
