Brother has a 64gt,289,auto.trans.Rebuilt about one and a half yr. ago not driven that much since car was finished, now it all at once decides it doesn,t want to shift from 2nd to drive,does not make any grinding or unsually different noises.Is their any simple things we could be looking for that we probably don,t know anything about, Bro is sdc member ,chapter member around Conway,Ark.Ideas?Thanks guys&gals. GL McVey Brother has no computer.
trans problem
Obviously, without checking, could be lotsa things. What you are saying is--it is HUNG in 2nd (that is, it decelerates rapidly when you let up on the gas in 2nd) or it won't shift INTO 3rd (the engine races when shifting out of 2nd)?
I had one once that just had no 2nd gear. You put it in D--nothing--engine raced. I could take off in low, then shift to drive, skipping 2nd. Very irritating. Finally had the 2nd gear band replaced and the valve body cleaned and it works fine now.
John
My first car was a 59 6 cylinder Lark that suddenly wouldnt go forward, only had reverse. Towed it home & sold it. New owner asked if I would tow it to his house, which I did. When I got there, he started it, put it in drive & took off. I never found out what might have happened. I would have kept the car if I had known it had fixed itself!
60 Lark convertible
61 Champ
62 Daytona convertible
63 G.T. R-2,4 speed
63 Avanti (2)
66 Daytona Sport Sedan59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
Try some Trans-X available at auto zone-advance auto parts and other places. A type of additive that sometimes will free up a sticking valve body which may be your problem. jimmijimsigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
Check the governor. See if the weight pin broke. You'll see an empty hole if it is.
Claude Chmielewski
Studeski
Fillmore, Wisconsin
47 M-16 Truck
62 GT Hawk
63 Lark
64 Commander Wagonaire
50 Champion Regal (parts car)
63 GT Hawk R2
[img=left]http://www.studeski.com/62hawk/62hawka/dakota01_250.jpg[/img=left]
1936 Dictator
1950 Champion Regal 4 dr parts car
1953 Commander Regal HT
1953 2R5 Pickup
1947 M16 Truck
1960 Lark VIII Convertible
1960 Champ 5E7 step side short box
1962 Champ 7E5 no box
1962 GT Hawk
1963 Lark VI 4 dr
1963 GT Hawk R2
1964 Daytona Convertible
1964 Commander Wagonaire
“America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.” ~ Abraham Lincoln
