A very simple process - just have to remember to cut a new tab for the inner bezel screw:
Detail of 4 headlight grille
2 headlight grille marked for cutting. Note area for tab. I used an angle grinder with a cutoff wheel.
Most of the cutting is complete
Speed nuts added to tab. Note that existing tab needed a new hole drilled.
Almost finished. The bezel fits perfectly. I do need to go back and carefully cut some tabs in the bottom to hold the bezel better. The 2 headlight unit only has 2, the 4 headlight one has 4 - see first picture.
Scott Rodgers
Los Angeles
SDC Member since 1989
'60 Lark HT
'63 Wagonaire
Scott Rodgers
Los Angeles
'60 Lark HT
'63 Wagonaire
