In Nov. I acquired a 51 Starlite to satisfy a life long interest in owing a classic vehicle.
After putting new tires on it and driving it around town for a while, I put the car up on stands to change the trans fluid and I noted that the front left tire was not spinning freely. Further investigation revealed a frozen brake cylinder which has lead to a rather extensive brake job. (Decided to replace the master cylinder but the lines were so badly corroded that I've been forced to replace the entire system.)
In working on the rear brakes I noted that the spring on the parking brake cable on the right side (the spring that is located just before the lever and pin mechanism) is broken in several spots but I cannot figure how to get the spring off so it can be replaced.
I have several questions. 1) is there a replacement spring that can be slid on the cable? 2) if there is, can the cable be removed from the backing plate without cutting off the retaining ball on the end? If the end needs to be removed to slide the cable out, how can it be reattached so the cable will once again fit into the brake lever mechanism. 3) if the rear cable needs to be replaced where can I get one?
I don't know if I am using all of the right terminology here. I'm pretty good at figuring things out but I am not a mechanic so anyone else that has tackled this problem I would appreciate their input.
I guess the good news is that although I am poorer because of the parts I've had to purchase, I'm still having fun
