View Full Version : Question for the rodders
JDP
12-23-2006, 07:37 PM
Oddly enough, the Studebaker truck drive shaft is the correct length if I can install the GM TH 400 transmission yoke on the shaft. I need a Universal joint that is Studebaker mechanics on one end and Saginaw on the other, any leads ?.
http://stude.com/sig.jpg
JDP
Arnold Md.
Studebaker On The Net
http://stude.com
My Ebay Items
http://www.stude.com/EBAY/
64 GT hawk
64 Commander 2 dr.
63 Avanti R1
63 Daytona convert
63 Lark 2 door
63 Lark 2 door #2
62 Lark 2 door
60 Hawk
59 3E truck
52 Starliner
51 Commander
CHAMP
12-23-2006, 08:03 PM
Your probably going to have to have a saginaw yoke installed on your driveshaft.
12-23-2006, 09:35 PM
Greetings, JDP,
Check with a good driveline shop or 4WD shop. There used to be some u-joints made just for odd-swaps. They came with GM on one axis and Spicer on the other. That way, didn't have to change the driveshaft.
thnx, jv.
parky
12-23-2006, 09:53 PM
JDP,
My '62 has one of those joints.
It has the orig drive shaft on one end and a 700R4 on the other.
It was on the car when I bought it. I'm going thru the documentation that came with the car and found a bill dated May, 2004 from "Suwanee Valley Rebuilders", 1350 E. Duval St., Lake city, Fl 32055 (386) 752- 8580.
It is for a 3-3130 U-joint at $34.07 and labor at $15 for a total of $49.07.
I'm pretty sure this is the bill for that joint. It might be worth a call to them and state your case.
I certainly hope this is the one, as I would like to repay you guys for all the help you have given me.
bob
62 GT Hawk
JDP
12-23-2006, 10:09 PM
Thanks guys, part numbers are just what I was looking for.
JDP
Arnold Md.
http://stude.com
My Ebay Items
64 GT hawk
64 Commander 2 dr.
63 Avanti R1
63 Daytona convert
63 Lark 2 door
63 Lark 2 door #2
62 Lark 2 door
60 Hawk
59 3E truck
52 Starliner
51 Commander
prager
12-24-2006, 03:06 AM
Any good local machine shop will have the know how to get you going..just give them the spline count/parts that you need to link..My local here made the switch over for me no probs..just tell them what your up to..they will take it from there..:)
Still working to restore my 62 Lark in South Bend, Indiana
DEEPNHOCK
12-24-2006, 09:29 AM
Sounds like you just need a 'combo' u-joint.
(2 big caps, and two small caps, with the trunion larger for the GM side.
Give Summit Racing a call. They do this all the time.
Just tell them you have a Ford driveshaft with a Turbo 400 yoke.
They'll know right away.
Here's one I 'think' might work:
Precision# 347
http://store.summitracing.com/partdetail.asp?sub=1&part=DCC%2D5007418&N=700+400185+115&rsview=sku
(spec's)
Brand: Mopar Performance Parts
Product Line: Mopar Performance U-joints
Solid: No
Greasable: Yes
Universal Joint Style: 1310
Bearing Cap Style: 4 plain
Bearing Cap Diameter (in) Axis 1: 1.125 in.
Width Including Clips (in) Axis 1: 3.270 in.
Width Overall (in) Axis 1: 3.675 in.
Bearing Cap Diameter (in) Axis 2: 1.075 in.
Width Including Clips (in) Axis 2: 3.270 in.
Width Overall (in) Axis 2: 3.675 in.
Universal Joint Material: Steel
Quantity: Sold individually.
Notes: Used to adapt 7260 driveshaft to 7290 axle yoke.
BTDT more than a few times....
http://i77.photobucket.com/albums/j54/deepnhock/Jeff%20Rice%20Studebaker%20Pictures/1937StudebakerCoupeExpressJeffRicee.jpg
DEEPNHOCK at Gmail.com
Brooklet, Georgia
'61 Hawk (project)
Alan
12-24-2006, 06:11 PM
Lakewood makes them but I don't have the part nos. on the top of my mind.
BeeJay
12-26-2006, 12:04 PM
Precision Part No. 372
Should be available at your local parts house.
Worked for me.
Own '53 Commander Starliner. Red w/beige top. 350 Chev/700R4. Tilt,cruise,A/C.
JDP
12-26-2006, 01:51 PM
372 is Saginaw to Spicer, I needed Saginaw to Mechanics.( See my drive shaft 101 post)
JDP
Arnold Md.
http://stude.com
My Ebay Items
64 GT hawk
64 Commander 2 dr.
63 Avanti R1
63 Daytona convert
63 Lark 2 door
63 Lark 2 door #2
62 Lark 2 door
60 Hawk
59 3E truck
52 Starliner
51 Commander
