How do you access the two rocker panel bolts on a 48 Champion /convertible?
rocker panel removal
Did you ever get an answer? I am trying to figure out how to remove/replace the rockers on my 48 Commander convertible. Somewhere I picked up the notion that as to the part to the rear of the door frame there are two bolts "inside the car" but I'll be dipped of I can find them. Any advice would be appreciated.
obermotor in Denver
I believe it's a "stud" at the rear of each rocker panel that attaches to the rear quarter; and the nut is accessed from under the vehicle. All else are spot welds to the body floor.Brad Johnson,
'56 Sky Hawk in process
Originally posted by rockne10 View PostI believe it's a "stud" at the rear of each rocker panel that attaches to the rear quarter; and the nut is accessed from under the vehicle. All else are spot welds to the body floor.Milt
1961 Hawk 4-speed
1967 Avanti
1961 Lark 2 door
1988 Avanti Convertible
Member of SDC since 1973
How about the body parts manual? That should show something.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
No luck. My rockers are rotted off at the end, so there can be no outside bolt holding them on. I'm tempted to put a thin sawzall blade in there and cut off whatever is holding them in.
TORQUE BOXES: these are also rotted on both ends. I don't want to replace them entirely, would like to just fab some new end pieces and weld them in. Does anyone know if they are supposed to be welded to anything at either end?
thanks for your help guys!
