I'm still trying to solve the draging noise in my left front brake. I replaced the return spring with a new one and was going to replace the eccentric spring clips, but they sent the wrong size. Also, both right and left spindles have what appears to be manufactured grooves on the taper. Is this normal?
The drag is on braking only, once per revolution.
The shoes are fairly new, 1500 mi., and didn't make the noise until about 600-800 mi.
My next plan is to take a gel ballpin and cross hatch both shoes, drive, and brake,the car to see if the wear is even.
These pictures are the best I can do, take a look and see if you can see anything I'm missing.
Dick
Mountain Home, AR
Dick
Mountain Home, AR
