Champ Pickup question
  • Champ Pickup question
    Does the Champ pick up use the same rims as a Champ car? Is the 3/4 ton rims like the old style rims like from a 58 transtar? How many lugs are there? Is a 1960 Champ pickup rim the same as a 1964? I think that about covers it. Thank you in advance
    Anne
    Mabel 1949 Champion
    1957 Silverhawk
    1955 Champion 4Dr.Regal
    Gus 1958 Transtar
    1957 Golden Hawk
    Fresno,Ca
    Mabel 1949 Champion
    Hawk 1957 Silverhawk
    Gus 1958 Transtar
    The Prez 1955 President State
    Blu 1957 Golden Hawk
    Fresno,Ca
    I'll answer some of these... others will also chime in I'm sure!
    1. No, the trucks use different rims than the cars - I think a 1/2 inch wider in most cases.
    2 & 3. A 3/4 ton Champ uses the same 8 bolt wheel as the 3/4 ton Transtar trucks did - although other wheel sizes (up to 17.5" were available).
    4. Remember that you could still get either 15" or 16" wheels for 1/2 ton Champ pickups in 1960 while by '64 it was quite rare to see any Champs with 16" wheels (and I'm not sure they were standard from the factory).
    <h5>Mark
    '57 Transtar Deluxe
    Vancouver Island
    The NW Overdrive Tour in Parksville, BC
    May 23 & 24, 2009; check it out at -
    http://sdcvi.shawwebspace.ca/
    </h5>
    Mark Hayden
    '66 Commander
      I don't think there were any champ cars. Champion is shortened to champ, but the champ is a t-cab pickup. Correct me if I'm wrong anyone.
        Well I meant Larks sorry the pickups and the Larks share the same style. Its been a long day. A friend was given a truck . It has flat tires . Trying to see if we had anything that would work for him. Thank you for the help.
        Is the bolt pattern the same?
        Mabel 1949 Champion
        1957 Silverhawk
        Gus 1958 Transtar
        1957 Golden Hawk
        Fresno,Ca
        Mabel 1949 Champion
        Gus 1958 Transtar
        Fresno,Ca
          Bolt pattern for Champ trucks different than later cars.
            The "T" cab champ truck uses the 5x5 bolt pattern, the car uses the 4 1/2 x 5 pattern, you can use the 5 lug chevy truck rims on the"T" cab drums, that is why you some times see the chevy rally wheels used on trucks...Bob
            Castro Valley, CA
            Candbstudebakers
            Castro Valley,
            California
              SASCO has some 5 bolt truck wheels in their inventory as well...
              <h5>Mark
              '57 Transtar Deluxe
              Vancouver Island
              </h5>
              Mark Hayden
              '66 Commander
                Anne If its 8 lug I was told once that is a unified lug pattern. Any (at least older) 8 lug should bolt up,just watch offsets. Steve.
                  Thank you.Very Much everyone
                  Mabel 1949 Champion
                  1957 Silverhawk
                  Gus 1958 Transtar
                  1957 Golden Hawk
                  Fresno,Ca
                  Mabel 1949 Champion
                  Gus 1958 Transtar
                  Fresno,Ca
