Anyone know why this does not fit a 50 champ? Only 51 up is listed ? looks good to me..any comments vs. MII approach? Seems better, about same cost net.. Anyone who has done this, even on a later car?
I have a (51) w MII, OK but not great , needed wheel space outs, about .75" with off the shelf backspacing aftermarket wheels in 51 starlight ; that aggravates balance and runout BS , don't like that part, still wide turning radius, or hits tire inside on frame/suspension. Not so easy to modify high end wheels.. Slickstreet looks like a great idea... I considered going mostly stock stude, later brakes etc, but wary of metal A frame "bearing" (?) setup, and vibration transmission to frame. wide open for input..
Some kind of kit to modify just the A arm to frame part to later rubber parts would seem like a good idea? Do later A arms with rubber fit, or anything like that? Maybe whole later suspension set up? But 50 champ has no bell crank, better i think.. looks like 60's Mopar steering , w idler arm , tie rod about at flywheel front, at space between flywheel and oil pan.(I thought that was a neat idea!) . A new box would be easy, keep all stock Stude, except A arm mounts ?
