View Full Version : need some information
Rob
12-18-2006, 08:43 PM
I have a 51` studebaker with serial#8207I72, Body tag# HF-5 3709, The engine#535601. Can some one please tell me if this is a champ. or a comm. and is this a true V-8 car.
Any Info. will be greatly appreciated. thanks
Swifster
12-18-2006, 09:08 PM
The serial number indicates that this is a Commander built in South Bend.
HF5 shows that this is Commander State sedan and the 3709 is the tub number for the shell. V-8's were available in '51 with engine numbers starting at 101 and up. There were 21,134 of these models built in all plants. the only way to varify if this is the original engine for this car is to get a copy of the build sheet from the Studebaker NAtional Museum. Cost is around $25. Most likely this is an original combination.
Tom - Lakeland, FL
1964 Studebaker Daytona
http://i74.photobucket.com/albums/i280/Swifster/Studebaker%20Stuff/StudeRear198x131.jpg http://i74.photobucket.com/albums/i280/Swifster/Studebaker%20Stuff/StudePlate-Single197x100.jpg
Michigan Speed - www.michiganspeed.com
Club Hot Rod - www.clubhotrod.com
LS1 Tech - www.ls1tech.com
Rob
12-18-2006, 10:25 PM
Thanks for the info. Swifster
Rob
12-18-2006, 10:49 PM
Is the engine a 232 V-8.
Thanks
Dwain G.
12-18-2006, 11:52 PM
The 535601 number you found is an engine block casting number used from 1955 to mid-1962. Try to find a STAMPED engine number at the front of the block on the oil fill tube from the number you found. That number will tell us what year and cubic inch the engine is (unless someone bored, stroked, etc.)
http://home.comcast.net/~jdwain/63.63.jpg
Dwain G.
Rob
12-19-2006, 12:46 PM
The stamped # is V542880
12-19-2006, 12:49 PM
Looks like a 1962 259.
http://www.studebakerdriversclub.com/tech_v8data.asp
http://static.flickr.com/140/326548308_6bc94ec0f3_m.jpg
Bellingham, WA
rockne10
12-19-2006, 09:16 PM
The 51 engine would have the number stamped at the back of the block, to the passenger side of the distributor.
Rob
12-19-2006, 11:06 PM
Thank all of you for the info.
