View Full Version : ned info for floor shift in truck
gotti210
12-18-2006, 07:30 PM
hey guys ive got a freind who has a 50 something studebaker truck with the flat six and three on the tree
and we are wanting to convert it to a floor shift
any suggestions
also is there any coversions out there to put a late model automatic of some other car brand trans behind this particular flat 6
garyash
12-18-2006, 09:09 PM
Here's how I put overdrive in my '48 M5 truck. The 1950's 2R series trucks are about the same as far as conversion goes on a Champ 6 engine.
http://www.studegarage.com/overdrive.htm
If you want a later model transmission, like a T-5 5-speed with built-in overdrive ratio, contact Bill Cathcart at www.cathcartsstudebaker.com for an adaptor to mount a T-5.
There is also this document on this site on mounting T-5 transmissions to Stude V8's, but the basics also apply to Champ 6 engines.
http://www.studebakerdriversclub.com/tech_5speed.asp
Dartmouth, Mass.
'48 M5
'65 Wagonaire Commander
'63 Wagonaire Standard
gotti210
12-19-2006, 10:49 AM
no i dont care about running an overdrive or anything like that just wanna get the shifter off the tree and to the floor
and studes are preety rare in this part of the country
so is there a way
like i said all we care about is a floor shift
Guido
12-19-2006, 12:33 PM
I think your conversion is going to depend on whether this is a Champion (170 CID) or larger Commander (245 CID) motor. The transmissions are different for each, but I think you could find a top loading Willys Jeep transmission that will work behind the small 6.
http://thumb14.webshots.net/t/53/453/1/21/36/2964121360097493054pVJTFL_th.jpghttp://thumb14.webshots.net/t/57/757/2/88/4/2023288040097493054SEKowB_th.jpghttp://thumb14.webshots.net/t/18/19/8/37/21/2050837210097493054IYBJJL_th.jpghttp://thumb14.webshots.net/t/59/559/1/43/57/2876143570097493054jKVhDw_th.jpghttp://thumb14.webshots.net/t/22/22/0/2/68/2589002680097493054ftBuBw_th.jpghttp://thumb14.webshots.net/t/28/28/8/30/30/2075830300097493054aSSlFv_th.jpghttp://thumb14.webshots.net/t/59/459/2/23/86/2067223860097493054YoeGMx_th.jpghttp://thumb14.webshots.net/t/28/28/5/18/33/2537518330097493054OgEKcN_th.jpg
RitchQ
12-19-2006, 01:43 PM
I have research a little about putting a floor shifter on but have not done it yet. I am going to do the same conversion from the tree to the floor as soon as I can. It seems that a Hurst 3 speed floor shifter will work -- you have to use different links due to the location of the shift links on the transmission. It looks like the location of the shifter on the floor would be located directly over the shifter links on the transmission and may be very close. There are a couple of previous questions about this on the forum. I think I remember a few pictures being there also.
I do remember that there is a Jeep shifter that can also be used but don't know the details or model of it.
If I get a chance to do this change I will take pix and post them for you.
Ritch
papasstudebaker
12-27-2006, 11:09 PM
you can use stop shifter 1946 to 1968 jeep 3 speed or a 61 to 70 scout
Vern Ediger
studeclunker
12-28-2006, 12:17 AM
PLEASE! When you make the change, DON'T THROW AWAY THE ORIGINAL SHIFTING BARS!! They are of great value to someone who needs them. They simply aren't available anymore.
http://i16.photobucket.com/albums/b18/Studeclunker/studebaby/54wagonblue-2.jpg
Lotsa Larks!
Ron Smith
