What color combination did the lark steering wheels come in and would that steering wheel bolt on to a GT Hawk steering column?
Lark steering wheels
Lots of combinations and solid colors. They were complimentary to all the different interior colors for the Larks. Red, blue, black, green, tan etc... If 2-tone, the complimentary color was "usually" white.
Yes, it's a direct bolt-on... but sometime in '62/3 they changed the turn signal system and horn switch. I believe all the Hawks to '64 used the plastic turn signal & "ring-type" cancellor switch. The horn wire went down through the steering column. (Ross)
Also, the horn rings are different- with the different style of spokes on the wheel itself (changed in '62 I think)
I think the change was when the Larks used the Saginaw Recirculating Ball steering box...
Ray
Ray
www.raylinrestoration.com
I agree. jimmijimsigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
