View Full Version : 3 Speed OD Shifter Mount Plates Found!
scott.rodgers
04-10-2009, 01:48 PM
I finally found a set of shifter mount plates for the T-96 3 speed OD tranny in my 63 Wagonaire!:
http://i394.photobucket.com/albums/pp21/apenaut/th_BOUi5ygBWkKGrHgoH-D8EjlLlcYWBJuDip0.jpg
It was on Ebay, listed for a 49-51 Ford OD 3 speed tranny. I have a Ford transmission book from the 50's - there was a T-96 listed for the years covered. I took the chance and bought the setup for $60. It fits perfectly, including the linkages. It was made for a Mystery Shifter, but the Hurst Indy setup I had worked just fine. The only modification I have to make to mount the brackets is to drill and tap a small hole in the tranny case to mount the side bracket - it's for the hole on the lower tab of the silver plate in the photo. I assume this had to be done for the tranny in Fords too.
Here's a picture of the brackets assembled. The top hole is for the shifter pivot:
http://i394.photobucket.com/albums/pp21/apenaut/2571333690100242519MhgWUq_fs.jpg
Here's the completed shifter in the car:
http://i394.photobucket.com/albums/pp21/apenaut/2229443640100242519SChrvL_fs.jpg
If you're looking for a floor shift for a 3 speed OD (at least a T-96), keep these pictures for your search. Unfortunately, I don't have a manufacturer or part number for the set.
If anyone knows of a shop that has one of those fancy automated plasma
cutters, I'd be willing to lend the pieces to anyone who wants to get the mounting plates copied - I'd like to get an extra set myself. If anyone has any ideas, let me know.
Scott Rodgers
Los Angeles
SDC Member since 1989
'60 Lark HT
'63 Wagonaire
scott.rodgers
04-10-2009, 01:50 PM
Here's a bigger picture of the mounting plates:
http://i394.photobucket.com/albums/pp21/apenaut/BOUi5ygBWkKGrHgoH-D8EjlLlcYWBJuD-1.jpg
Here's the top plate mounted on the tranny in my 63' Wagonaire:
http://i394.photobucket.com/albums/pp21/apenaut/2020225290100242519fGABPQ_fs.jpg
Scott Rodgers
Los Angeles
'60 Lark HT
'63 Wagonaire
Mark57
04-10-2009, 02:21 PM
Excellent Scott! I know I sure like having a floor shift (T-86) much more than a column shift on my Transtar. :)[^]
<h5>Mark
'57 Transtar Deluxe
Vancouver Island
The NW Overdrive Tour in Parksville, BC
May 23 & 24, 2009; check it out at -
http://sdcvi.shawwebspace.ca/</h5>
http://i186.photobucket.com/albums/x153/MarkH57/IMG_0368a.jpg
scott.rodgers
04-10-2009, 02:38 PM
Mark,
I do like a floor shifter better, especially with a 3 speed. Now I can mount my Ididit column with tilt!
Scott Rodgers
Los Angeles
'60 Lark HT
'63 Wagonaire
04-10-2009, 02:58 PM
T-96??? or T-86???
You runnin' a OHV 6 in that Wagonaire???
1963 Cruiser
1957 President two door
scott.rodgers
04-10-2009, 04:13 PM
T-96 and yes, I do have an OHV 6.
Scott Rodgers
Los Angeles
'60 Lark HT
'63 Wagonaire
