Just purchased a 53 Commander Starliner and I have a couple of question.
1.The car is mostly rust free ie floors, trunk and etc are good, however rocker panels have some rust coming through. the inner rocker panel appear good. I removed the threshold cover and everthing is clean there. The question is--How difficult is it to replace the outer rocker panels? Are the seams welded together, could not tell from just looking at.
2. Has original engine. compression is 100-120, cold, throttle not open. The engine seems to lack power. Is this typical for this compression--manual says 120-140. Will a 289 bolt up to the original auto transmission? and is original rear end up to handling the 289?
Any help with these questions would be appreciated.
Thanks, John
Thanks, John
